Door openings are not showing
13 ANTWORTEN 13
Nachricht 1 von 14
2368 Aufrufe, 13 Antworten
I'm working on a student project and the door openings are not showing up nor are the walls connecting or the cut pattern showing, what could be wrong? I've checked the construction type and they are the same. My view range is correct (at least that I know of). Since I put topography in things are not working right and I've come to far in my project to start deleting things. revit.JPG
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Anonymous
Are you in a Floor Plan View?
Nachricht 3 von 14
als Antwort auf: barthbradley
Yes I am in floor plan view
Nachricht 4 von 14
Let's have a look. Post the file.
...here's a list of things to check when you can't see stuff.  Keep it handy for future reference too.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
...here's my guess: there is no Opening in the Family or the Void Opening is not cutting the Host in the Family.
Nachricht 5 von 14
No openings work for me, roof is showing in floor plans, I honestly have no idea what happened.
Nachricht 6 von 14
Your View Range settings are wrong. Lower the Cut Plan to intersect with the Door Opening.
Nachricht 7 von 14
They are though, level A as at the right elevation therefore I used that as the base for the view range..
Nachricht 8 von 14
Nachricht 9 von 14
You figure it out yet?
Nachricht 10 von 14
Yes, sorry for the delay. How do I get the door panels back?
Nachricht 11 von 14
Get rid of view visibility and graphic overrides you put on the panels.
Nachricht 12 von 14
Nachricht 13 von 14
Great, thank you so much!
Nachricht 14 von 14
