In my project, I have two layers of walls, due to the design. I'm also modelling the baseboards as wall sweeps. When I add a door that is meant to cut through both layers of walls, I use the join tool to join the two walls, and this works so the door penetration cuts through both walls. However, this doesn't extend to my wall sweep baseboard. Is there a way to get the door to cut through all the layers automatically? Or is there a way to manually cut the wall sweep in two segments to generate the opening?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Oh My god, that worked! I thought it made more sense to keep it checked. Thank you very much!
