Door opening cutting into wall behind
7 ANTWORTEN 7
Nachricht 1 von 8
579 Aufrufe, 7 Antworten
Running into an issue with doors in the angled wall. For some reason, if I go to a door wider than 4' in this wall it cuts into the wall behind.
Beschriftungen (3)
7 ANTWORTEN 7
Nachricht 2 von 8
syman2000
als Antwort auf: Anonymous
Share the family. I want to check and see if void is used in the family. It may impact your object host and cut into multiple walls.
Nachricht 3 von 8
als Antwort auf: syman2000
Here is the family I am using.
Nachricht 4 von 8
I have found that if I unjoin the corner the problem goes away. So I assume it is not caused by the family.
Nachricht 5 von 8
Did you join the corner by Wall Join or Join Geometry?
Nachricht 6 von 8
als Antwort auf: ToanDN
By wall join
Nachricht 7 von 8
This is the corner I had to remove the join on.  @ToanDN
Nachricht 8 von 8
Can you share the project or a portion of it?
