I placed a 10' tall door in an 11' tall wall, it looks fine on the plan view, but is cut off at 8' on the elevation view. It appears correct placed as an 8' tall door. with the taller door the opening is only cut at the 8' ht...
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Maybe the Cut Opening in the family isn't locked to the Door Height parameter so it remains 8'.
Check the parameters of the family. Cut Opening may be controlled there.
Void Cut in family is not constrained. Align and Lock to top Ref. Plane.
edit...it's depth wasn't constrained either. see new attachment.
