I am creating a door legend which includes frame types and door elevations. The frames went in fine. The doors elevations come in only as left elevation right elevation or plan view . Any suggestions
Gelöst! Gehe zur Lösung
Door you know where these doors came from? Whose library? If the panels are nested then you may need to focus on placing a legend for the door panel family versus the door "host".
Steve Stafford
Sorry, I reversed what I intended in my earlier reply. I've seen nested panels display their right and left side when Front or Back is chosen. The parent family (host) that the panels appear in show correctly. So, if the door families you are using have nested (shared) panels and you are trying to place a legend component for the panel versus the door family then what you show is consistent with my observations. Make sure you're placing the door "host" family.
Steve Stafford
