door is not intersected with the wall!!
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
wolfman00100
482 Aufrufe, 3 Antworten
hi
i was modifying the plan and accidentally moved the door to a wrong place where it could intersect with a wall but i dont understand why revit is not showing me an error !!:grinsendes_Gesicht_mit_Schweißperlen:
3 ANTWORTEN 3
Nachricht 2 von 4
hmunsell
als Antwort auf: wolfman00100
because technically it is still "in" the wall (just not all of it). if you were to move the door or wall so it was completely outside the wall you would get a message.
Howard Munsell
Nachricht 3 von 4
wolfman00100
als Antwort auf: hmunsell
i am sorry i dont think that is the problem i used to do this and get an error
even now i try to create a new door or a window intersecting with wall and there is no error.
i have attached a video showing my workflow please can you tell me what is wrong ?
thank you.
Nachricht 4 von 4
hmunsell
if you move a door or window perpendicular to a wall (or visa-versa) you get an error. but not if you move it in line with the wall. i'm not saying i agree with it.... it should warn you either way.
Howard Munsell
