Door insert at the top
elias_munoz_neyra
elias_munoz_neyra
Greetings,
I was always curious about door inserts and their logic. One can configure wrapping, but does it only affect when in plan view? THat is horizontally, but not in section? Or should I only add a detail for the top of the door?
Thanks in advance for your reply
True. Wall wrapping is cosmetic and plan only. You need to add detail in the family if you need go show it for every section thru door.
elias_munoz_neyra
THanks for the suggestion and fast reply. I was wondering how to handle the issue. This cleared my thoughts definitely
