Door header in RCP showing up as solid gray-- how to make them white?
2 ANTWORTEN 2
Nachricht 1 von 3
372 Aufrufe, 2 Antworten
The door headers are showing up as solid gray in the RCP views. How do I get them to show as white? Here is an image of what is happening:
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Change the Visual Style to Hidden.
...or, Paint it.
Nachricht 3 von 3
Redrunner92
To start, I advise you check the Material applied to the headers. If either is set to show a grey color in their Surface or Cut settings under the Graphics tab, that would do this. Let us know if this isn't the issue.
