Does anyone have any idea why the door frame in this family is displaying "above" the Wall?
See attached family.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
I looked at the family and it is a family aligned with the door panel as a frame / mullion.
What you can do is change the thickness of the cut line of the frame/mullion of the doors in your project model to a thinner one, do this in the graphic visibility settings, or in the object style.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
Curious design. Why doesn't your opening cut through the wall? Is this a faux window/door?
You have to go into the door panel. Select the line and checked off draw in foreground.
This should set them not at the front
Hi I only have symbolic lines in the nested door panel.Not the fixed frame which is obscuring the wall.
I unchecked that option in the nested family but it doesn't seem to do anything n my end.
Could you possibly resend me your amended file please?
You apply the same so the lines will be below the wall. See attached
I'm really inept at building families. Its a source of huge frustration for me.
