Door frame cuts deeper than I need when placing on the wall corner
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
tharushadd
739 Aufrufe, 10 Antworten
There is this wall corner I have in my design where I want to place a timber door frame family. The door frame family is placed in a 9" thick wall. I have drawn in red colour how I want it to be placed? I am planning to cut a void in the wall where there will be a rectangular timber piece as shown and insert an in-place rectangular timber piece. Can someone help me to solve this issue?
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: tharushadd
Move the door down?  The create an in place mode wedge piece if you need to, or just leave it at is then you have the bit of the wall left as the wedge.
Nachricht 3 von 11
RDAOU
@tharushadd
You need to model that in the family
  • A Custom Frame with that timber backing
  • and a custom VOID extrusion to cut host at an angle instead of the Wall Opening tool which only cuts host orthogonally
Nachricht 4 von 11
tharushadd
als Antwort auf: RDAOU
Hi, this seems the solution. But are there any related tutorials to follow? I mean how to do it.
Many thanks for the reply.
Nachricht 5 von 11
RDAOU
@tharushadd
It is simple...
  • edit the family >>
  • delete the Wall Opening (you should be able to tab select it) ...
  • and create instead a void extrusion which has a trapezoidal shape (cuts wall at an angle)
  • Make another extrusion for the timber subframe
I dont know any specific tutorial that matches this case ...BUT the best tutorial on Doors is this 20150420 20150421 Tutorial Making Detailed Revit Door Families - YouTube
Nachricht 6 von 11
tharushadd
Thanks. I am trying it. Thanks again
Nachricht 7 von 11
tharushadd
I've tried what you suggested. In fact, I added a parameter to control that angle baking.  But when I try to add it to the project there is a problem of determining the exact angle and entering the value onto the parameter. It results in a slight change and an unwanted line in the wall like in the attached image. Can you please help me on this too?bah2.jpgbah3.jpg
Nachricht 8 von 11
RDAOU
@tharushadd
If you want the angle to be  parametric, you will need to use a reference line or  the face of a revolve...it will not work with a reference plane...
No access to a workstation at the moment, once I do, I will put something together for you to check.
Nachricht 9 von 11
tharushadd
Here is the family attached!
Nachricht 10 von 11
tharushadd
No worries. I used reference lines and used global parameters to get the dimensions correct. Thanks again. Everything works perfectly!
Nachricht 11 von 11
RDAOU
Good ... well done mate
