Door family not working as expected
4 ANTWORTEN 4
Nachricht 1 von 5
reut.h
376 Aufrufe, 4 Antworten
I created a door family based on the default doors in Autodesk's library.
The door has an angle parameter (Instance Parameter) and a Antipanic Handle (Type Parameter)
For some reason,
When I change the door's width:
1. The antipanic handle is no longer hosted to the door.
2. The antipanic handle is not in the aligned to the center of the door.
What could be the reason? See the attached files (Revit 2023).
Thanks!
Beschriftungen (3)
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: reut.h
Hi!
The door and the antipanic handle  works fine here for me. I tested several door angles (90º,45º,0º...)
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
reut.h
als Antwort auf: vitorbortoncello
Hi
Thanks for looking into it.
Have you tested the one with the door width=120?
The problem starts when I change the width of the door.
Nachricht 4 von 5
vitorbortoncello
it was a constrain problem, i "realigned" it
Nachricht 5 von 5
reut.h
Can you send it in Revit 2023 by any chance?
And show me where it wasn't aligned.
I'm about to lose my mind :denkendes_Gesicht:
By the way, in the version You sent me the handle is still not aligned to the center of the door
