Door Family - Not recognizing Pinned Reference Plane when loaded in project
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jstipanovich
204 Aufrufe, 2 Antworten
I've built our single door families so that when the width of the door is changed, the hinge side location stays static, while the rest of the door assembly increases in width.  It works perfectly fine in the family editor when I flex the door width, however when I load it into a project and flex the width, the family behaves as if  the center of the door is the pinned reference plane.
I don't know why it is behaving correctly in the family environment and not in the project.
Any ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
blank...
als Antwort auf: jstipanovich
Reference plane which you pinned in family editor, also mark it as "Defines Origin" (in its properties).
This will, however, then also be the insertion point for the doors.
Nachricht 3 von 3
jstipanovich
als Antwort auf: blank...
omg... what a total brain fart on my part.
THANK YOU!!!!
