There are these instance parameters that I cant make disappear. They are not a part of the family itself. They are actually text parameters. They don't show in the project parameters dialog box or using Ideate style manager. Its like they are built in and invisible. Does anyone know if its possible to remove these?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
I believe this is default system parameter that cannot be deleted. It shows up in sample file as well
I was thinking this may be the case. Thing is, the naming convention we currently have for doors has the door panel and frame material built into the name. So this opens the door for mistakes. For example if there is door 36" x 80"_SC_HM for solid core and hollow metal frame, then the material can be changed from something other then what the name specifies. So would you guys recommend not using this naming convention?
Depends on your project type. Typically I use a schedule key so those instance parameter will tie to value specified in the key schedule. It helps if you are doing a large complex project with various hardware and material. You don't want to create hundreds of door for different type when you can control it using schedule key.
