Announcements
Door Family, Angle Parameter
dm0144
dm0144
Hello everyone
I am creating double door family with two symmetrical swings.
The issue occurs when I constrain the reference line to the horizontal plane and the vertical plane (left and right vertical plane respectively, which define the door width parameter) in order to create axis of rotation. When I add door angle parameter between the horizontal plane and the reference it works fine for any angle, apart when I set the angle to 0.00 degrees, when each reference line gets constrained to the opposite vertical plane, than the door angle parameter doesn't work any more.
Any clue why is this occurring?
Replies (7)
kadmonkee
try setting the precision of the angle higher 0.00001 the increment of the angle 0.000 could be causing the constraint issue
the graphic result will be small enough to appear closed
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
syman2000
This is a known issue with reference line with angle. This is why I don't use this approach and opt for sweep angle and have family panel hosted on the face of the sweep angle. See attached.
I don't seem to have that problem.  I opened your file in 2022 and it works fine changing the angle to 0.  Attached is a similar 2019 file.  See if you can break the constraint.
dm0144
@ToanDN Than, when I input another value different than 0, the constraint breaks, one ref. line gets constrained to the opposite vertical ref. plane. After that, both ref. lines get connected at the common end point.
We must have been using a two different programs then.
https://knowledge.autodesk.com/community/screencast/b201e515-3847-47b8-a74b-5d671a56be33
dm0144
@ToanDN Could bi a bug for certain Revit versions? I am using 2021.
Anyways, Is there a formula to input any value except for 0?
RDAOU
@dm0144
That is not a bug in the coding sense. That happens when you enter the angle in the Dimension Label (what you are doing) BUT NOT when you input the angle values in Family Types dialog (what @ToanDN  is doing in his screencast).
  • One way around that is to Shorten the Reference lines (give them a fixed locked distance - say 40mm) so that they do not meet and automatically lock when the angle is 0 - The length of the Reference Lines is irrelevant to that of the Panel width. The reference lines are used only to host the Panel and drive the rotation, not to drive its length.
  • Another way is to have the left and right rotating panels modeled EACH in a separate family and nested in.
There are a few other ways but the above 2 are the basics when it comes to rotating panels using reference lines.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
