Door doen't cut the wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mairh_tsek
390 Aufrufe, 4 Antworten
Hello all,
When I place the door in the wall it doen't create the opening. Do you have any idea?
(see the image)
Thank you in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mairh_tsek
Could be several reasons. Do you have an Opening or Void Cut in the family? Are you sure it's not cutting?  Are you in a Plan or RCP view?  Maybe it's a Phase related?
Post the file.
Nachricht 3 von 5
Check the door offset....or do you have a linked file?
Nachricht 4 von 5
Corsten.Au
1. There might be two walls at the same location.
2. Test that door if it cuts the wall on different wall...
Best luck
Corsten
Building Designer
Nachricht 5 von 5
mairh_tsek
als Antwort auf: Corsten.Au
Thank you for your answers. Yes, finally I had two walls in the same location.
