Door detail settings
4 ANTWORTEN 4
Nachricht 1 von 5
roscopeco2000
471 Aufrufe, 4 Antworten
Hello I have a french door i downloaded from the Bim store. Its displaying to much detail in my floor plan and i dont want to see so many lines in the cill. The lines i want to turn off are not 3D parts which i can turn off in visibility graphics.  When i bring it into my floor plans it almost looks transparent, can anyone direct me how to change. I have attached the family.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: roscopeco2000
I opened your door family and set the visibility of the sill to only show in fine detail views.  You can also set it to not show in plan.
Nachricht 3 von 5
roscopeco2000
als Antwort auf: Anonymous
thanks but i don't want to turn it off just not see so much detail. Its not just the cill, the whole frame looks like wireframe mode? your example looked good.
Nachricht 4 von 5
Looks like you are in Wireframe. Change the Visual Style to Hidden.
Wow! I just opened your RFA.  Heck of a lot of geometry linework visible at the Cut Plane in Plan View.  You ought to Mask it out or turn it off, and use a simple Detail Linework representation instead.
Nachricht 5 von 5
roscopeco2000
als Antwort auf: barthbradley
I know its a mess, when i open up the actual family part it looks fine. Is there a cut plan view within the family? so i can see the same geometry and maybe change the lines to invisible ones?
