Hi all,
I want to create a door such that. No matter what I do (Change Ref. Plane) Offset will be placed always Above the Ref. Level.
Any Idea?
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
Draw and dimension (edit: i assume it's locked btw) the reference plane above the Rev level...
You can easily enter a NEGATIVE value for "Sill Height" in the Project. This will drop the Door and Opening downward from the Ref. Level.
Set the referenceplane @Anonymous Ref.level property "Defines Origin" on.
and lock it to the ref. level itself if not already.
