Hi all.
I got a question regarding door family.
When I select door in the project, dimensions next to door automatically appears.
And it is very easy to move precisely.
But in some cases, door does not generate auto dimensions.(I think it is a problem of family)
Could anyone advise how to turn on the auto dimension? (rather than a Activate Dimensions button)
In addition, in some project, automatic dimension is generated from center line of wall.
How can you control auto dimension appearance?
Thank you.
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Nested (Shared) families won't generate Temporary Dimensions as you've observed.
It's a quirk of multiple selection. The same thing happens when you select more than one element, which a family that has a nested shared family is...more than one element. The nested shared state means the nested family is also loaded into the project individually so it is no longer merely symbolically represented.
Click Activate Dimensions...
Re: Temporary Dimensions - You can influence where they appear by default via Manage ribbon > Additional Settings > Temporary Dimensions. Once you drag a temporary dimension to a new reference Revit attempts to remember that change for the current session. It will reset when you close Revit.
The appearance like a dimension style is not adjustable however.
Steve Stafford
