Door and windows!
1 ANTWORT 1
Nachricht 1 von 2
mrheuseler
197 Aufrufe, 1 Antwort
Door and windows!
Hello experts,
I need help!
Trying to figure out, why I can see the Door-swing and the window "lines" in 3D?
I only need to see the Window-lines (please see att. picture!) in Front/Back.
The Door swing, only in Plan-view.
I have tried to set the Window lines to "Opening [projection]" and "Window [projection]". AND - Changed the "Visibility Settings" to "Front/Back". But I can still see it in 3D.
What am I doing wrong?
Thank you.
Kind regards
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: mrheuseler
what line did you used > use symbolic lines instead of model lines. thanks
