(done)how can a family sweep locked to reference lines? any tutorial link about parametric family for complex shape?
2 ANTWORTEN 2
Nachricht 1 von 3
heichan88
1747 Aufrufe, 2 Antworten
I make a sweep in family, unlike extrusion which can locked to reference lines, the sweep cannot locked or adjusted with parameter.
can could you advice any tutorial link about parametric family for complex shape?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: heichan88
@heichan88
Using Pick path already locks the sketch lines to the edges of 3D model element or to the reference lines...However, if the 3D model elements or ref lines are locked to reference/work planes => then the sketch lines of the sweep path are too indirectly
Alternative is - when you are creating the sweep do the following:
  1. Use Sketch Path - NOT Pick Path
  2. Set Work Plane to the reference plane or face where the reference line is hosted
  3. Align and lock
Nachricht 3 von 3
Create the sweep path by Pick 3d edges and lock the path to the ref lines or edges.
