Don't want to allow copy between to Revit File
4 ANTWORTEN 4
Nachricht 1 von 5
eridhima1990
249 Aufrufe, 4 Antworten
Hi!
How can I not allow to copy between 2 revit project that are not in collaborate?? So disable the option aligned in Current View?
Thank you in advance,
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: eridhima1990
You cannot disallow or disable the option. You can only ask your team mates not to do it and hope that they dont
Nachricht 3 von 5
Make it into your team's Standard Operating Procedure.
Nachricht 4 von 5
eridhima1990
als Antwort auf: RDAOU
Or maybe there is a way so I can move the entire project and so when they try to copy something it won't happen due to the fact that is the same project.
Nachricht 5 von 5
RDAOU
@eridhima1990
the Hide 'n Seek strategy you mean?
Put it in a folder which they do not have access to!! But what would you do if you need to link and workshare such model files?! you would be back to square 1
There is no other solution. You and you colleagues are all grown up professionals and need to work and trust one another...if there is not trust in a team it wont what rules and procedures one sets or writes.
