Does someone have a 1' x 6' tile pattern with half-offset?
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
mlhier
499 Aufrufe, 7 Antworten
7 ANTWORTEN 7
Nachricht 2 von 8
lucdoucet_msdl
als Antwort auf: mlhier
@mlhier
You can create your own pattern file based on replacing the A and B values in the following PAT file description:
*HATCHNAME, Standard stretcher bond A=length x B=height
0, 0, 0, 0, B
90, 0, 0, B, A, B,-B
For a Revit model hatch you need to include the appropriate header depending whether the units are metric or imperial as described in the online Revit help link below.
Hope this helps,
-luc
Nachricht 3 von 8
mhiserZFHXS
pyRevit also has a wonderful tool to create custom hatch patterns right in Revit. Tons of other tools, but that's probably my favorite.
Nachricht 4 von 8
rxi.gg
Pyrevit allows you to easily create your own patterns
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 5 von 8
Not sure about your mortar spacing but this is a typical 10mm offset with a running bond pattern.
Kristina Youngblut
Product Owner - BIMWorkshop
BIM Coordinator - CIMA+
25+ years Autodesk User
LinkedIn
Nachricht 6 von 8
@kristina.youngblut
If the OP had supplied a joint width, I agree that the pattern file would be significantly more complex. I assumed they wanted a model simple schematic pattern for small scale floor plans and elevations.
-luc
Nachricht 7 von 8
lucdoucet_msdl
@mlhier
The free version of the website link below is useful in adjusting and understanding the hatch pattern definitions. For example, adapting and existing pattern to new dimensions and spacings.
https://pattycake.io/new/drawing
Hope this helps,
-luc
Nachricht 8 von 8
hugha
try this:
; Written by HatchKit 4 Professional Edition
; HatchKit 4 Professional Edition (c)1990-2022 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2022/05/21
;-Time : 17:35:52
;-HatchKit 4 Version : 4.3.0.3186
;%VERSION=3.0
;%UNITS=INCH
*Halfoverlap6ftx1ft,Stretcher bond
;%TYPE=MODEL
0,0,0,36,12
90,0,0,12,36,12,-12
hth,
Hugh Adamson
