Hello Everyone,
i am struggling to in some areas
appreciate your all guidance
Gelöst! Gehe zur Lösung
Gelöst von JasonKunkel. Gehe zur Lösung
Hi
You need the original Shared Parameter File " Notepad "..
probably try to create a new Shared Parameter file and then create
custom " shared parameter " and use them...
Its impossible to get " Shared Parameter file " used in any family..
but if you can manage to get it then that will help you edit and add
shared parameters..
Best luck.
This is a very late reply, but I wanted to add some clarification in case other folks find this via a Google search. The COBie Extension does not allow adding extra parameters to the typical columns for export. That is not COBie compliant. To get extra parameter data exported, you need to use the Attribute tab. If you go to Setup in COBie Extension and find the Attributes section, check the boxes for the parameters you want. Then those associated parameters will show up on the Attributes tab in the exported spreadsheet.
Hello @JasonKunkel
Thank you for posting!![]()
This will be helpful for the community seeking similar answers!
I've added more related information (your screencasts) and on COBie Extensions
Screencast: Autodesk COBie Extension for Revit - Parameter Mapping
COBie Extension for Revit - Parameter Mapping to Revit Category
Autodesk COBie Extension for Revit - Parameter Mapping Tips
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
You cant add parameter but you can revise parameter mapping, it can change the exported cobie sheet,
