Does Autodesk Flow recognize Revit mass drawings?
1 ANTWORT 1
Nachricht 1 von 2
350 Aufrufe, 1 Antwort
Does Autodesk Flow recognize Revit mass drawings? Where can I find Autodesk flow user manual?
1 ANTWORT 1
Nachricht 2 von 2
loboarch
als Antwort auf: Anonymous
It is called Flow Design. You can access learning content here:
https://knowledge.autodesk.com/support/flow-design/learn-explore/caas/CloudHelp/cloudhelp/ENU/FlowDe...
The last time I used it I believe Revit mass elements (as well as other Revit elements) are recognized by Flow Design. Here is a sample video of the Revit sample model in Flow Design.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
