Hi all,
I know my question may need to go to a different forum but I thought there might be some people who know where it exists in the dynamo library and could help me out.
Thank you,
Leo
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thank you I actually found and found that it is not part of the preinstalled library
What? You didn't like my answer? Before you can use the node, you have to install the Steamnodes package. That's the information I provided. That's the information you need.
What does that mean? That was clearly evident from your first post. You didn't have the node installed. In order to install the node, you need to find which package contains it and then load that Package into Dynamo so use can use the node. I thought you were wanting to know what Package, not a confirmation that you don't have installed -- or what it would look like if it was installed, as @ToanDN showed you.
The correct answer and accepted solution should have been post #2.
