Do Revit 2024 or any revit version provide a feature to save revit files to its lower version.
Either revit families or revit project can be saved to lower versions.
No!
however…There are two work arounds (both not ideal) which might help if you are desperate.
You can export Plan Views to DWG which can then be imported into an older version of Revit. It’s not a Revit model but it’s something that might save you some time re-doing the work.
Export to IFC, again not ideal but IFC files can be imported by older version of Revit. You may experience data loss and the 3D geometry will no longer be Revit elements but it might get you out of a pinch.
Help | Backward compatibility of Revit with earlier releases of the software | Autodesk
this has been asked so many times already
DarrenP
