Division doesn't work in parameter
19 ANTWORTEN 19
GELÖST
Nachricht 1 von 20
4485 Aufrufe, 19 Antworten
Hi, I want to add formula to coverage parameter which calculates as foot print area/lot area. But I get inconsistent Units. I know that coverage is text parameter and foot print area/lot area are area parameters, but I can't find any solution. Thanks for helping
19 ANTWORTEN 19
Nachricht 2 von 20
als Antwort auf: Anonymous
You cannot have a Text parameter as a result of math formula.  It should be a Number parameter.
Nachricht 3 von 20
why is coverage a text parameter? Do you want it to return a value of "Too Much" or "Too Little" or "Just about Right"?
Nachricht 4 von 20
als Antwort auf: ToanDN
I changed it to number and this time got another error "Division By Zero", and still doesn't let me write A/B
Nachricht 5 von 20
Because your B = 0 base don your screenshot.  Change it to a different value before adding the formula.
Nachricht 6 von 20
change it to a length parameter.
Nachricht 7 von 20
als Antwort auf: barthbradley
Change it to Lenght, but it says" inconsistent unit"
Nachricht 8 von 20
Add * 1" or / 1" to the end. I'd explain why this works, but I'm pretty sure you'll get it once you think about it.
Nachricht 9 von 20
Looking at you screenshots I assume you want to get a ratio between 2 lengths, or between 2 areas. Is it correct?
Nachricht 10 von 20
Absolutely,
Nachricht 11 von 20
Basically you need to ensure three things:
1. Your equation does not divide by zero. EVER.
2. Your equation returns a value of the type expected (a number parameter in most cases).
3. If the parameter is expecting an area, that it returns SQUARED units (may have to multiply by 1 unit in order to square). If it is just a number that it returns NO units (may have to divide by 1 unit in order to remove units). If it is a length that it returns a united value (may need to multiply by 1 unit in order to add units to value or divide by unit to make squared units into units).
Nachricht 12 von 20
Inside the family, the values are all 0, but inside the project, they are fillable as you can see in attached files. You are right the division doesn't work because the values are 0, but I don't know what to do.
Nachricht 13 von 20
Just enter some value for A|1 to A|14 in the family so you can finish the formula. They are place holder numbers and can change in project.
Nachricht 14 von 20
Ohh, Thanks it did work, but this time the rounding is grayed out :enttäuschtes_Gesicht: I need to have 32%
Nachricht 15 von 20
Edit the label format and change to Fixed  Percentage.
Nachricht 16 von 20
How should I do that?
Nachricht 17 von 20
Nachricht 18 von 20
This is Awesome , thanks
Nachricht 19 von 20
By the way, adding /1 and *1 as suggested by @Anonymous is a good way to iron out the Inconsistent units in a formula when the parameters in the formula are not of the same Type (Length vs Area vs Volume etc...).
Nachricht 20 von 20
GHASEM_ARIYANI
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
