You can create a Shared parameter of the text type that can be used for all types of elements, select a whole house and fill with house 1, house 2 etc. and then filter or organize in the schedules by this created parameter by house.
(or use an existing parameter like "comments")
The typical approach is to create a separate file for each building model and terrain model. Then, link all building models to the site and proceed with coordinate sharing.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
