Dividing and merging surfaces
Message 1 of 8
Hello, I'd like to divide a mass surface into two surfaces to apply different patterns to each, is there a way to achieve that?
Replies (7)
Message 2 of 8
cbcarch
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
add edge to form
Message 4 of 8
Thanks for your reply! I should have been more specific: I want to use an arc or a spline to divide the surface; unfortunately, adding an edge doesn't help in my case. Is there a way to split the surface like using intersects but the result would be two new surfaces?
Message 5 of 8
Duplicate the mass family, edit and add a void to cut one half.  Edit the other one and cut the opposite half.
Message 6 of 8
Thanks for replying! I would like to create an effect like the one in this picture, but using splines?Sage BuildingSage Building
Message 7 of 8
Alright! I shall try it as a last resort. Thank you.
Message 8 of 8
Viveka_CD
Hi @Anonymous
That's a cool effect that you are trying to create.
Another workaround is to use Repeat and divide curved panels in a curtain wall system for the facade.
See video below:
You might also want to look at massing and curtain wall systems
I hope that helps! Please feel free to post a screencast or a file from your attempt so far so that we help better!
