Why does the border of a divided surface using adaptive curtain panels overshoot the actual border by 2"? I tried to find this answer but couldn't. Here is a picture of a conceptual mask for a lattice using a rhomboidal pattern. Notice that the model is larger than what the edges should be. Is there a workaround? This is in an orthographic view (west) in a project with mass turned on and mass nodes turned off.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@ToanDN & @barthbradley Thanks. I guess that's the answer, not that I like the solution but it's in the hands of the developers.
Actually, the one good thing about this BUG! (yes! I said it!) is that it is consistent. It is always exactly 2-inches, so the workaround always works perfectly. Probably better to describe it as a "workflow" rather that a "workaround". Autodesk ought to just own it now and stop updating the Incident Report every year with the same old Status line: "This incident is being investigated for a possible cause and resolution."
BULL-SH*T!
@barthbradley wrote:"This incident is being investigated for a possible cause and resolution."
You misspelled, i [g] n ve [o] r stigat ed.
