Hi all,
Am I mistaken, but can you not divide Volume by Area (or vice versa) (on a schedule for example)?
In this instance, I was trying to schedule thicknesses of materials of a wall, by dividing each material's volume by their area - as Revit apparently doesn't include the thickness parameter in the available fields automatically... Haven't figured a way around it, that doesn't include updating data manually.
Gelöst! Gehe zur Lösung
Gelöst von Mike.FORM. Gehe zur Lösung
Gelöst von blank.... Gehe zur Lösung
You can, the issue is you're trying to use different units in the formula.
Solution:
That's interesting. I could have sworn I tried that one. Maybe there was a typo that time... Anyway. Thanks! This works too.
