Divide Surface Glass not forming to shape (Curtain Panel Pattern Based)
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1228 Aufrufe, 10 Antworten
I have a custom "In Place Mass". Then I divided the surfaces to create a glass roof of sorts. I created a custom Curtain Panel Pattern Based family for this mass and the glass isn't forming to the shape of the form.
Did I not place the glass properly in the Curtain Panel Pattern Based family? I have the mullions down. I just need the glass to flow along with them.
Have a look at the attached screenshots!
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
How did you create the glass pane?
Nachricht 3 von 11
als Antwort auf: ToanDN
By modeling a simple rectangle withing the Curtain Panel Pattern Based template family inside the wood frame.
Nachricht 4 von 11
If you grab one of the 4 points and drag it, does the glass pane stretch to follow?
Nachricht 5 von 11
No it does not follow.
Nachricht 6 von 11
Then it does not work properly. Share the family here.
Nachricht 7 von 11
Attached is the file.
Nachricht 8 von 11
Try this one.
Nachricht 9 von 11
It works! Thank you ToanDN!
Can you explain how you did this?
Thanks!
Nachricht 10 von 11
All the geometries in the family should be based on the 4 adaptive points in order to flex properly: each green reference line is created from 2 points; the frame is a form from a profile sweep along the reference lines; the glass pane should be created based on the same logic.
So, I deleted the old glass panel, then selected the 4 green reference lines and created a new form, give it Glass material.
Nachricht 11 von 11
gossipgras000
Based on your description, you have created a custom "In Place Mass" and divided the surfaces to create a glass roof. However, you're encountering an issue where the Curtain Panel Pattern Based family's glass does not conform to the shape of the form.
To troubleshoot the problem, it's possible that the glass placement in the Curtain Panel Pattern Based family needs adjustment. While you mentioned having the mullions set correctly, the glass itself is not flowing along with them.
To provide more specific guidance, examining the attached screenshots you mentioned would be helpful. Please include the screenshots so we can better understand the issue and provide appropriate assistance.
Thank you in advance, and we look forward to reviewing the screenshots to help address the problem.
