I'm working on switching from CAD to Revit as my main program. Previously, in CAD, I have a block set of ADA compliant public bathroom options that I would load into my DWG, explode the block, chose the best fit option, insert it into my drawing and explode/edit if needed. Is there a way to do something similar in Revit? I work on commercial projects and don't want to spend time making a restroom for each project with all the required clearances.
If I make a family for each bathroom option to load into my project, is there a way I can "explode" (like CAD) to edit anything if needed. For example, if I create and load in a "bathroom option A" and have more room in the space to make the restroom larger, could I edit that bathroom (without changing the original family) and move a wall out to make it larger?
If anyone has any other suggestions of other ways to go about this, I'd love to learn!
