I want to display existing walls set to demolish when I am in the New and Existing Construction phase.
First I created a Revit project with phase set to existing. When I change the properties of existing walls to demolish they change to dashed lines. That's great. When I set the phase to new constriction, the existing walls to demolish are not visible. I want to see them. What do I Do?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
In Phase Filter, choose option : Show All
If you have the options: Show Complete or Show New, the Demolished entities will not appear
Constantin Stroescu
I want the demolished entities to appear along with new construction. Why? Because a remodel job is evolutionary as the design is developed. Having to change to existing phase to view walls to demolish is not useful because the new construction is not visible. If I want to demo just a portion of an existing wall it is useful to see where new walls will be positioned.
In summary, I want to see the dashed walls to be demolished and to née new construction at the same time. Can it be done?
Hello, check my screencast video if this is you wanted it to be. Thanks
That setting is not working for me. I wonder the phase filters or graphics overides need to be changed under Manage > Phases settings. see my settings in the attached .png file
what you demonstrated is beyond my area of expertise. I am an architect, not a computer program customizer. If that is what it takes to display walls to be demoed on the same drawing as walls to be constructed, I'll figure something else. Thank you for your interest is assisting me.
How many Phases do you have?
Is the Phasing of the existing walls to be demolished set the same as below?
Phase created: Existing
Phase demolished: New Construction
If so, it should work.
Have a look at my screeencast:
I've made here a new Phase Filter to show how override works .....
Maybe it could help you somehow....
Constantin Stroescu
Thank you! I will give that a try. One question, when you changed a wall to demo, could you have just gone to the bottom of the properties for that object and change the "Phase Demolished" to existing? Anyway, i will create the new phase filter and see if I can duplicate what you illustrated. Thanks.
If you want to demolish an Existing one then you are doing it in New Construct : Phase Demolished > New Construct ( the phase in which you proceed with demolition)
Constantin Stroescu
Pay attention at Phase Filters : Demolished > NOT TO BE set on Not Displayed ( for Show Complete , Not Displayed is by default setting). The Phase Filter made in my screencast ( Complet+Demo) has the Demolished to Overridden
Constantin Stroescu
@Anonymous
The phase filter you showed is perfectly fine. Your existing walls to be demolished must be created under Existing phase, and demolished under New Construction.
