Displaying Light Fixtures in Electrical Plan
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
ethanjekandem
4751 Aufrufe, 7 Antworten
Hello, I'm trying to have my electrical plan (Right) display the light fixtures from the ceiling plan (Left).
I'm not sure the steps needed to do this.
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
Hi @ethanjekandem  check the range of view
Juan Francisco Angel
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Luego haga clic en el botón ACEPTAR SOLUCIÓN.
Nachricht 3 von 8
MuirEng
als Antwort auf: ethanjekandem
Hello,  I'll try and answer in general terms.
First, you need to insert the light fixtures into the model properly. They can be either hosted on a ceiling or a work plane. Open a ceiling plan and make sure the view range extends high enough that the lights will be visible. Then insert the light fixtures to the ceiling (if you have one in the model) or to a work plane set to the ceiling height.
You can choose to display the light fixtures in your floor plan (for a combination plan) by extending the view range of the floor plan up high enough to see the lights.
Brian Muir, P.Eng, Muir Engineering
Nachricht 4 von 8
als Antwort auf: MuirEng
In the light fixture family, create a model line that extends from the origin point on the light fixture, to the ground plane. Use an invisible line for the the line type. This will allow the light fixture to extend into the cut plane for your electrical plan and be visible. If you already haven't, you will want to turn off light fixtures in your main floor plan template.
Nachricht 5 von 8
Nachricht 6 von 8
codescad
I had the same problem and found I had to select the view and change Properties -> Discipline, from Architectural to Electrical. Also ensure your view range is set the the proper elevations/offsets.
Hope this helps others,
Cheers
www.codescad.ca
Nachricht 7 von 8
bill_gilliss
als Antwort auf: codescad
I use Discipline = Coordination to see everything, then turn off unneeded categories in VG.
Nachricht 8 von 8
joseph_shealy33TGH
als Antwort auf: bill_gilliss
THIS WAS HELPFUL, THANK YOU
