Display problem intercepting a solid
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
455 Aufrufe, 12 Antworten
Hello friends of the forum, I need your valuable help, I upload two images, the one on the left is mine and the one on the right is where I want to go, I want to know how to see the reinforcement intercepting the solid of the prefabricated concrete beam, the visualization I do not like it, it seems that the reinforcement is outside the concrete beam. I appreciate your helpefecto.jpg
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
Change the Structural Framing category to have some level of transparency.
Nachricht 3 von 13
reinforced concrete I-Beam? Is this a real thing?
Nachricht 4 von 13
als Antwort auf: ToanDN
riends thanks for answering, I found the solution, I'll publish it, only I've been busy, thanks in advance
Nachricht 5 von 13
als Antwort auf: barthbradley
That's how my friend seems, it's a design from a colleague, it's not mine, I'm just modeling it.
Nachricht 6 von 13
Honestly, I think you're misreading his design.  There's no such thing -- at least in the real world.
Nachricht 7 von 13
Honestly if this is wrong, for the sake of engineering I will make you know :), he only asked that the way that beam, as an example, I only did it for exercise. Review endures any abuse by our perverse minds
Nachricht 8 von 13
Nachricht 9 von 13
I managed to solve in the following way: in the visualization of the steel you have to deselect the option "see uncovered elements" and in the 3D view, in view properties deselect "show edges" that was it.view!!!.jpg
Nachricht 10 von 13
thank you friend for responding in my last reply I show what I wanted to obtain and how I achieve it! in a bad English, but I think it will be understood!
Nachricht 11 von 13
Sounds kind of convoluted. Did you read the article I Linked you too?
Nachricht 12 von 13
Well duh. Stupid question. I can see you are using the information in your solution.  Cool, huh?  Glad I could impart to you my wisdom -- and help you get the coveted Solution Credit.   Smiley (zwinkernd)
Nachricht 13 von 13
I can share my glory with you :), hehehe, I have no problems
