Is there a way to display multiple Design Options on a sheet?
When i change an Option in a Option Set, it changes in all Veiwports.
An Alternate work flow for having multiple plan configurations on a single sheet is also great.
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You should be able to create different views for different Design Options, go to VG > Design Options tab > and change it there for each view.
Set the Design Option for the View under VGO Design Options tab. Not "Automatic".
