DISPLAY DRAFTING VIEW
Message 1 of 8
When I insert a drafting view and then I tarnsdfer that  drafting view to a sheet , Is there a way that I can aply something like a clipping mask? Because I don't like to see some of the elements as I have shown in the image below.
Replies (7)
Message 2 of 8
rodrigo.bezerra
Yes, you can apply a masking region. However, seems to me like you have a drafting scale issue.
Regards
Rodrigo Bezerra
Message 3 of 8
Thanks but unfortunately the masking region is greyed out.'
Message 4 of 8
rodrigo.bezerra
Are you trying to apply the masking region directly on the sheet? Because you can't. You can only do it inside dhe drafting view.
If you don't want do leave the sheet screen to do it, select the viewport and go for the Activate View on the ribbon. Then you can edit whatever you want/need. To deactivate, right click without any object selected and then click Deactivate View.
Regards
Rodrigo Bezerra
Message 5 of 8
I went to activate viewport adn its greyed out and doenst move out of the command
Message 6 of 8
SOrry I overlooked your last sentece as its 2 am here.I also don't know how to make the lines around the filled and or masking region go away as shown in the image below.
Message 7 of 8
rodrigo.bezerra
Please watch the screencast attached.
Rodrigo Bezerra
Message 8 of 8
RDAOU
@Anonymous
When you draw a masking region to make stuff invisibile...you need to use invisible lines 🙂 ... (get some sleep mate Reviting at 2am is no good)
