Disk Space Error when Installing Revit 2018LT
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2017 Aufrufe, 5 Antworten
I go to install my download of Revit LT 2018 and it tells me I have insufficient disk space. I've got 11GB on "C" and 1TB on "D". I'm trying to install on "D".
Rob Burkhart
Owner - A-daptive A.P.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
While you can install the program files on your :erschrockenes_Gesicht: drive, there are some files that have to be installed on your C drive, especially in your c:\Temp directory.
Try clearing out some of your TEMP files in the C drive and your user account to get some extra space.  You will want at least 20GB for swap files to run Revit correctly.
Nachricht 3 von 6
Viveka_CD
Hi @Anonymous
Sorry to hear that you are facing issues with the downloads and installation.
please see link HERE for an article on "Install error:Not enough disk space"
Also check a similar discussion HERE
Let me know if you were able to resolve your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question.Kudos welcome.
Nachricht 4 von 6
Viveka_CD
als Antwort auf: Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Nachricht 5 von 6
chrisplyler
He doesn't have enough disk space to reply.
Nachricht 6 von 6
Viveka_CD
als Antwort auf: chrisplyler
