disassociating dimensions instead of deleting them.
thomas.mackay
thomas.mackay
When you remove an item, or adjust or simply hide it, then any associated dimensions disappear. This is not a problem if you literally see it happening, however, this is often (especially with larger projects) not the case. It would be better if, instead of being deleted, the dimensions would become disassociated and get a different colour and/ or some kind of tag so that they can be identified and adjusted, and or filtered out. It happens often that an item gets adjusted on one sheet, but that a dimension gets deleted somewhere else entirely - it's almost impossible to keep track of and can often be problematic. I'm thinking for example, of dimensions that HAVE to be present in order to comply with planning regulations. Is there a way to stop dimensions from getting deleted and to tag those that get disassociated in some way as mentioned above?
RSomppi
No, there isn't. Awareness that they do get hidden along with the object is key.
You can post it to the Revit Ideas forum.
