Hallo all,
we have a weird problem in Revit with one of our team members of disappearing dimesion lines in a small particular part in the view
In 2 situations we realised the dimensions disappeare:
1. The disappeared Dimesnions are attached to this element, so when the element is hidden and revealled it back on, dimesnsions are not there.
2. When clicking over the dimensions lines and then click in the drawing area.
i have read and searched about the same problem, but could'nt find anysolutions or work arounds, can anyone help?
Make sure your DWG drawing is smallest possible (and close to CAD zero). I am not talking about file size.
Having elements in DWG which are far away from the actual drawing you need, or having DWG drawing far away from the origin may (will) cause problems in Revit.
What are we supposed to see that's different in all these screenshots. Maybe you can post a less "busy" view so we can easily see the difference. I mean, not everything in the view is behaving badly; right?
