Dimmension Length VS Schedule Length
2 ANTWORTEN 2
Nachricht 1 von 3
wr.marshall
239 Aufrufe, 2 Antworten
In a project I am working on we have non linear boundary walls. I have dimensioned the wall length however they are not matching the scheduled wall lengths. There are 2 ways I could rectify this. Option 1 is to add a column and manually type in the dimensioned lengths. Option 2 is to use reference planes and try measure the scheduled length. Both options will cause issues as they would need to be manually revised if there is a change. Please suggest alternative methods to to marry up the figures in plan and the schedule. attached screen shots for reference.
The first is a snippet screen shot showing the non linear walls along the boundary
the second screen shot is the scheduled lengths. The first 3 rows are as per the plan view., so ignore the last 2 rows.
2 ANTWORTEN 2
Nachricht 2 von 3
Ilic.Andrej
als Antwort auf: wr.marshall
The schedule line is not the same as the annotation because it is generated by the wall location line. Once two walls are joined at the corner, their location lines adapt.
Maybe this old post will be of some use.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 3
Length of wall is measured from centerline end points.   Is that where your dimension's Witness Lines originate from?
