Dimention the core of a partition with a finish wrapped end.
1 ANTWORT 1
Nachricht 1 von 2
chrisd1
246 Aufrufe, 1 Antwort
This is a major oversight in the Wall/Dimensioning ability.  I'm sure everyone has made an uncased opening before, or a wall partition that is not joined on both ends.  See attached screen capture of a partition next to a toilet.  The only way we could work this out was to add an additional wall made of sheetrock only and aligned it to the end of the partition.
That 2'-0" dimension should be able to work in Revit without a work-a-round.  Framers need dimensions to framing not finishes.
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: chrisd1
Wraps have zero BIM value. They are purely cosmetic.  Typically we model wrapping because of this.
