Dimensions
5 ANTWORTEN 5
Nachricht 1 von 6
becca
248 Aufrufe, 5 Antworten
Dimensions
On the floor plans, sometimes dimension strings appear, for example: a dimension string that is on my second floor plan (architectural plan) shows up on my second floor framing plan (structural plan) without me having added it there.  When I click on the dimension string (because it shouldn’t be there) it disappears.  The two plans are the same floor plan but independent of each other.  Any idea what is causing this?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: becca
Nachricht 3 von 6
becca
als Antwort auf: barthbradley
No, these are not temporary dimensions. These are dimensions that have been placed on a floor plan to dimension something on the floor plan but then appear on a framing plan even though they were not placed in that plan. When you click on the dimension that is there, it disappears. Sort of the exact opposite of temporary dimensions.
Nachricht 4 von 6
Huh?  Want to post the file?  Even a screenshot might help.
Nachricht 5 von 6
Corsten.Au
One possibility.. is
“ Reveal constraints” is switched on.
It’s the second last icon on lower ribbon..with the lock..
Corsten
Building Designer
Nachricht 6 von 6
becca
als Antwort auf: Corsten.Au
Thank you, I will check this!
