you cant change the value of the dimension to change the length of the wall (Image 1)
if you select the wall, then select the dimension value (image 2)
it should allow you to change the value
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
