Dimensions section in Properties Pallet when select a wall
2 ANTWORTEN 2
Nachricht 1 von 3
allaweya
166 Aufrufe, 2 Antworten
Hello Revit forum
Generally, when select a wall there are three instance parameters in Dimension section in Properties Pallet, these parameters are Length, Area and Volume
I ask about the rules applied by Revit to calculate Area and Volume and Length of WALL SELECTED in a model
Kind Regards
2 ANTWORTEN 2
Nachricht 2 von 3
yazdan0191
als Antwort auf: allaweya
Length would be straight length.
Area would be one side L x H
Volume Would be Area x Width
Nachricht 3 von 3
allaweya
als Antwort auf: yazdan0191
It seems that you are not understand what I refered to
What I mean is when you finish creating an architectur model and go to make a Wall schedule that include fields such as Area, Length, Volume, we will discover that there are a rules that control computing Area and volume and length
I found some hints in the following link in Youtube but I don't found all answers about all rules that control above scheduled fields
https://youtu.be/aRY2ish1AcY?si=ROjtnV7N_k4jw6VD
Note: I show here a link includes an example of a wall schedule that exported to Excel (distance is 12' between Level 1 and Level 2)
https://1drv.ms/x/c/ac822c5dc82a8a59/EamrDRPpH2FDr_2O4S38dcEB7gVnJgD1Ifd6jAYxFO5h4A?e=97I6Lp
