How can I have in the dimension lines both metric and imperial measurements?
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
…. Hi @Anonymous
…. Go to your plan
… click on one dimension (it will turn blue)
…..click in Edit Type
…. In alternate units chose below
…. And in alternate units format click to open and chose feet and fractional inches
…. Click ok
… done
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
.... also you can see here a couple of options
... to get the dimension on the side, etc...
http://blogs.rand.com/support/2012/03/duel-dimensions-in-revit.html
aRcHiTeCt.JM
REVIT EXPERT ELITE
