I have two instances of the same link, first instance is dimensioned in its own view and I'm trying to copy paste those dimensions to the new view showing the other instance and none of the dimensions can't find a reference.
This was working fine up until now and I was doing it extensively for the past 2 months on this project.
I have tried unhiding everything before pasting, dimensions are getting pasted perfectly aligned to grids.
Any solutions? I really need this back, and I don't know what has changed that it doesn't work anymore.
Luka
Gelöst! Gehe zur Lösung
Gelöst von lumoric. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
A more reliable approach is to place dimensions in a linked view and set the Link instances in your project's views to display by Linked view. But feel free to share the files if you want us to look at them.
If the two link instances are not at the same location, how do you copy paste dimensions from one view to another?
Lol, I managed to resolve it. It's always the simplest solution...
The other instance was rotated ever so slightly, don't even know how I've noticed that.
