Dimensions among other things do not import well. You will need to recreate them.
revit and autocad work in different way so you will not be able to import form autocad to revit specially if you are using the autocad as a drafting tool
regards
if you find my answer useful do not hesitate to give me a kudos and if it the solution please mark it so the other can benefit from it .
