dimensions across view breaks
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
kgatzke
5764 Aufrufe, 16 Antworten
Why do dimensions spanning across view breaks in sections or elevations become unmodifiable?  The drag text button can't be picked and the text can't be picked either so you can't modify it.
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: kgatzke
It works fine here.  Have you audited this project recently?  Does it work in a new from template project?
Nachricht 3 von 17
kgatzke
als Antwort auf: Anonymous
I created a blank from template project like you suggested.  I made two walls and section view of them.
I placed a dimension between the walls and then broke the view into two sections.  I could still move the dimension text and change it.
After I drag one of the view regions I can no longer drag the text or change it.
Nachricht 4 von 17
That seems odd.  I just dragged the regions and was still able to affect my dimension.  Are you all up to date with service packs, point releases and such for your version of Revit?
Nachricht 5 von 17
i there:
I’ve experienced this issue before in earlier versions of Revit, with 2016 this is no longer the case.
The way I did manage to work around it, was to pinpoint the location where the dimension text need to be placed (once the section breaks are incorporated), eliminate the breaks,  finalize the edits to the dimension string, and then proceed to re-do the section breaks.
Glad that with Revit 2016 you are able to select and edit the dimension without the workaround.
Nachricht 6 von 17
kgatzke
Your method works but I've found that I can reapply modifications to the text if I drag the view breaks back to their original parting distance.  Undoing the break isn't necessary.  Then all you have to do is drag the view breaks back together.  It's as if the space the text controls sit in no longer exists when the view breaks are close together so even if you can see them you can't touch them.
Nachricht 7 von 17
muthomimunyua
This worked for me perfectly. Thank you.
Muthomi Munyua
Nachricht 8 von 17
B.I.Smith
This issue seems to be back. Working in Revit 2020.2 and having this issue now. The same goes for level markers. Cannot modify or select.
Nachricht 9 von 17
mbrooksX66XY
als Antwort auf: B.I.Smith
Looking for a solution to this also.
Nachricht 10 von 17
Also looking for a solution to this in Revit 2021.1.1.
Nachricht 11 von 17
Base12
Having the same problem in 2021 (worked fine for me in 2018.2)
Nachricht 12 von 17
chauh
2020.2.5 Has this problem as well.
Nachricht 13 von 17
als Antwort auf: chauh
Duplicate View as Dependent, Uncrop the Dependent view, Edit dimension.
or
Duplicate View as Dependent, Unclrop the Dependent view, drag the dim text a bit the you can edit it in the broken view.
Tags (2)
Nachricht 14 von 17
JennSen
Also looking for solution in 2022.1, one that works with details views that can't be duplicated as dependents. Tried several things found here, none work.
Nachricht 15 von 17
als Antwort auf: JennSen
- Duplicate the Detail View with Detailing, unbreak the copied view
- Place dim on the copied view, drag dim text away from where the break would be
- Copy the dim and paste align to the original broken up Detail view
or,
- Place an Ordinate dim directly on the broken up Detail view
- Drag the Ordinate dim's text a bit (because Ordinate dim's text is near an witness instead in the middle, so you will not have any problem doing so)
- Change the Ordinate dim to Linear and the text is still accessible
Nachricht 16 von 17
Base12
Still a problem in 2023... have to "un-break" the viewport, edit your dimension, "re-break" the viewport and reset to previous location (gosh forbid it should just remember what the previous location was).
Nachricht 17 von 17
adam_pembleX57VA
als Antwort auf: Base12
I am having the same issue in Revit 2024.3.
Revit also rotates the dimension text, with or without any edits, when I PDF the drawing!?
